djdave238's avatar
Dec 08, 2022
R6330 Support?
Is the R6330 still supported with security updates from Netgear?  I haven't seen any firmware releases in many months, and my product page says "Your R6330 with serial number [redacted] no longer has software support." Not sure if that means "Online Product Support" or if it means they've dropped the maintenance of this unit's firmware.
    • djdave238's avatar
      djdave238
      Guide
      Yeah, I noticed several R6300 models were already out... maybe I should just dump this thing then.
      • plemans's avatar
        Guru
        Is it working and meeting your needs? If so, no need to dump it. Half the security updates are a bit bunk and not usable for the vast most or they need access to the device to execute it anyway.
        If its not, then its time to upgrade anyway as its getting a little old/slow compared to the newer stuff.
