Orbi WiFi 7 RBE973
Reply
WINDR4500 V2
jj8279
Initiate
WINDR4500 V2
Hi.  I have an older WINDR4500V2 router, primarily used as a secondary router for my wireseless security cameras.  Is there any way to remotely login to this router?  The nighthawk app claims the router is too old and I struggle to find a way.
Thank you.
Message 1 of 4
Guru
Re: WINDR4500 V2
is it setup in router mode or access point mode?
(if its a secondary router, it should be in access point mode)
What I usually do is remote into a computer on my network and use that to access the ip address of the router. Tends to be the fastest
Message 2 of 4
jj8279
Initiate
Re: WINDR4500 V2
I'm not 100% sure and at work at the moment but I think router mode.  I will definitely check when I get home.
Perfect.  Thank You!
Message 3 of 4
Re: WINDR4500 V2
What do you want to do with remote login?
Your decade old router certainly predates most of the easily accessed features.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 786 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
