× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNDR3400v3 - firmware update to v1.0.1.24
GeoHead
Initiate
I did a firmware update last night and all appeared to be fine until I went to my iphone & ipad to access WiFi. The network shows as it always has but it doesn't like my password on either device, even though they are stored on the devices. I've tried rebooting my unit but there's no change. I've tried re-entering my password and no luck and I'm confident I'm using the right password. I've even tried changing the password from my PC but it doesn't like the password. I even punched in the old original password that came with the unit and it didn't like that either.
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: WNDR3400v3 - firmware update to v1.0.1.24
> [...] I've tried rebooting my unit but there's no change. [...]
   The next step would be a settings reset.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Factory Settings"
(or "reset").
   Restoring old saved settings could restore the old problem(s), too,
so a manual reconfiguration will be required after the reset.
Message 2 of 4
All Replies
antinode
Guru
(or "reset").
Message 2 of 4
GeoHead
Initiate
I tried the reset button on the back and that didn't work. I then went to the manual as suggested and found how to erase it back to original settings and that did the trick.I'm back in business.....Thanks !!!!
Message 3 of 4
antinode
Guru
> I tried the reset button on the back and that didn't work. [...]
   "tried" how, exactly?  Used according to the instructions in the User
Manual, it should.
> [...] I then went to the manual as suggested and found how to erase it
> back to original settings [...]
   How was that?
> [...] I'm back in business [...]
   Thanks for the report.  (What could go wrong?)
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1880 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
