× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNDR3400v3 is very slow with firmware v 1.0.1.4_1.0.52
tpsynd
I recently updated the firmware in my WNDR3400v3.  The version now installed is 1.0.1.4_1.0.52.  All connections, wired and wireless, are very slow with this new firmware.  My internet provider indicated that Netgear firmware has a problem and has released a beta version to fix the speed issues.  How do I either go back to the old version of firmware or obtain the beta version?
Message 1 of 3
Accepted Solutions
tpsynd
Re: WNDR3400v3 is very slow with firmware v 1.0.1.4_1.0.52
I did the factory reset after submitting the question, it seems to have helped.  I am monitoring it for a few days to see if things are improved.
Message 3 of 3
All Replies
ElaineM
NETGEAR Employee Retired
Welcome to the community, @tpsynd
Did you factory reset the router after firmware upgrade?
After factory reset, reconfigure the settings and verify your speed.
To downgrade the firmware, you download the previous firmware from this site and follow the instructions below on how upload it.
How do I manually upgrade firmware to my NETGEAR router?
Message 2 of 3
tpsynd
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2871 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
