- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDR3700v2 attached USB drive is lost to Windows 10 following a reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
After I reboot my pc running Windows 10, it is unable to reconnect to a WD 500GB USB drive attached to my WNDR3700 router, over both wired (Broadcom Netlink Gigabit Ethernet card) and wireless (Broadcom 802.11n Network Adapter). Even if I 'disconnect' the USB drive in File Explorer, I cannot re-map a drive letter to it. However, the USB drive looks fine from either my tablet (also Windows 10) or Bluray player, both connected wirelessly.
I am up-to-date on all drivers/firmware on the PC and router as far as I know. Since the problem happens when connected both wired and wirelessly, does this indicate a problem with an Ethernet driver on the PC?
Thanks
Geordie
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Perhaps that particular computer needs reformat?
Try to back up and format.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDR3700v2 attached USB drive is lost to Windows 10 following a reboot
So when you lose it from your computer, the USB drive is still accessible from your tablet and your Bluray?
If yes, then it could be something on that Windows 10 PC.
You may want to try to scan it for some malwares or have it reformatted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have done a full sweep of the system using ZoneAlarm with nothing found. Since the tablet works okay, I know it is not a fundamental problem with Windows 10. I read some other threads about a similar issue with Windows 8, but did not find a solution there.
Geordie
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you mean reformat the drives, or reinstall Windows 10?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It could be both.
Since the other Windows 10 doesn't have any problems at all.
But then again that's a tablet they're both different.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, so I backed up everything, formatted C: and the installed Win10 from scratch. Currently everything is looking good, and I have even fixed some "Unknown USB device issues". Now all I have to do is reinstall/rebuild everything, which should keep me busy for a few days and certainly stress test the system.
Thanks for the help
Geordie
- Mark as New
- Bookmark
- Subscribe
- Permalink
Awesome!
