- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Will there be a problem connecting old router (wndr3700) to a newer cm2000 modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a newer modem cm2000 can I use a older router wndr3700, with out any problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Will there be a problem connecting old router (wndr3700) to a newer cm2000 modem
No, but you may lose a lot of performance.
The original WNDR3700 came out in 2009.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently purchased netgear modem CM2000 had a problem with set up through comcast
finally got it working 900 to1000 mbps through the direct cat 5 connection to desk top. connected my old router WNDR3700 works great on all 4 lan hooks ups. Problem with
the wireless, vary weak.did I miss a setting or is the router just too old, and what router
would be adequate
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jdgra wrote:
Problem with
would be adequate
Hard to diagnose without more details on the WiFi and what you are doing. What does very weak mean? Slow, I can understand, but not weak.
The WiFi range of the WNDR3700 won't be up to much, and it won't support as many clients as newer routers.
Then there are the possible security challenges on a device that may not have had a firmware update in some years and won't support newer WiFi security protocols.
If you have an Internet service at 1000 Mbps, that router just won't give you the best performance possible, network technology has come a long way since 2010.
The CM2000 should do a good job with a better router.
I don't want to scare you, but I wouldn't even give that router to anyone who wasn't an enemy.
As to an alternative router, start here:
Wireless Routers for Home | NETGEAR
Try plugging your needs into the filters.
Netgear isn't the only option, but you will be familiar with how it works and it could be easier to get it to work with your modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can use that router/modem combination.
But like @michaelkenward says, you're loosing a lot of performance with that router.
Its ancient and not going to have the greatest wifi (or wired) capability.
