× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wired connection not an option for firmware fix
gailouise
"WNR2000v5 Firmware Version 1.0.0.42" suggests a wired connection be used for firmware upgrade.  I live where wireless is my only option. Shall I go ahead anyway?
Model: JWNR2000v5|N300 Wireless Router
Message 1 of 5
Accepted Solutions
gailouise
Re: Wired connection not an option for firmware fix
antinode:
Thank you.  Yes, I do have an Ethernet cable connecting my desktop computer to the router. I did not know that this was considered a "wired connection".
Thanks for educating me!
Message 5 of 5
All Replies
ElaineM
NETGEAR Employee Retired
Welcome to the community, @gailouise
It's highly recommended that you use wired connection when uploading a firmware to the router.
Wireless connection may corrupt the firmware of the router if ever you lose wireless connection.
Message 2 of 5
A wired connection really is the best idea, but a lot of people have successfully flashed over wifi.
Too help you to reach a decision, check what the release notes say about the new firmware. Some updates are there to fix security issues. Some people think it essential to fix even the most theoretical security holes.
Message 3 of 5
antinode
Guru
   Are you saying that you do not have any computer with an Ethernet
port which you can connect to the router?
   You don't need a wired connection to the Internet.  The firmware
upload may be more reliable if there's a wired connection between the
computer with the Web browser (and the firmware kit file) and the
router.
Message 4 of 5
gailouise
antinode:
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2383 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
