- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
enable telnet on R6300v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model R6300v2, stock firmware V1.0.4.24_10.0.87.
OS: Win7/64 on my desktop.
I'm trying to get telnet access to the router.
I have tried the telnetenable, telnetenable2, and telnetgear utilities, to no avail. The unit just refuses the connection. Also tried port 223. No joy.
10.0.0.1/debug.htm raises a 404.
If I flash to a previous firmware version (and which one?), will the access — or custom settings — "stick" when upgrading back to current?
I could flash with dd-wrt, but on a previous unit I could not get the USB storage/NAS to work in spite of doing everything By The Book. (My shares were visible but inaccessible in Windows' file explorer, and the NAS was completely invisible on my other system on the LAN, so I'd like to stay with the stock firmware if I can.)
I opened a ticket with Netgear support — a week ago. No response at all.
Suggestions re enabling telnet welcome..... TY in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
For others:
http://www.antinode.info/nte/index.html
Download & extract nte-05/nte-05_win.zip
Run it from the Windows CLI.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: enable telnet on R6300v2
> [...] I have tried the telnetenable, telnetenable2, and telnetgear
> utilities, to no avail. The unit just refuses the connection. [...]
On my D7000, I use this: http://antinode.info/nte
"tried" + "to no avail" is not a useful problem description. It does
not say what you did. It does not say what happened when you did it.
As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Which MAC address are you specifying? (You want the LAN-port MAC
address.)
"tried" _what_ on "port 223"? I wouldn't expect anyone to be
listening there.
Also not amazing. There is one on my D7000 (V1.0.1.64_1.0.1) but it
doesn't offer a Telnet-enable function. There is a "Module Debug" page,
"/debug_mbm.htm", with an "Enable Telnet Server" control which does
nothing obvious, other than leading to a "403 Forbidden" error page.
Hence, I use that "nte" program. If nothing else, it provides
potentially useful error messages.
pro3$ nte m=50:6A:03:E9:AE:86 n=10.0.0.1 u=admin p=password ! LAN MAC.
nte: Received ACK message. Telnet access should be enabled.
pro3$ nte m=50:6A:03:E9:AE:87 n=10.0.0.1 u=admin p=password ! WAN MAC.
nte: FAIL. No ACK message received
- Mark as New
- Bookmark
- Subscribe
- Permalink
My apologies. The brevity of my description assumed others had run into the same issue.
Tried means:
In PuTTY — the router's current address (10.0.0.1) on Port 23, "Telnet" radio button selected, option for "Close on exit" set to Never
Result: Black PuTTY window. Dialogbox errmsg "PuTTY Fatal Error" (titlebar) and "Network error: Connection refused"
(Port 223 was suggested by someone elsewhere as an alternative for these routers)
In telnetenable2 — (yes, this is the MAC addy of the router seen from the LAN)
telnetenable2 10.0.0.1 04A1512574CA admin [my router pwd]
returns
"starting ..."
"creating pkt..."
"sending pkt..."
"done."
But still can't telnet to router. Same err as above.
In telnetgear.exe —
Router local IP, MAC addy, setup login & password, and hit Connect
"ERROR 10060: :Connection timed out."
Is there anythying else I can try? And do you know where I can find a Windows version of nte? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] do you know where I can find a Windows version of nte?
There's a link on the web page:
NTE 0.5 Executable Kit
o Windows executables kit:
If you use the NTE Windows executables which I built, then you may
also need to install the appropriate Microsoft Visual C++ 2010 SP1
Redistributable Package. For details, see:
https://community.netgear.com/t5/x/x/m-p/1388903
(That thread provides a solution to another possible problem.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm sure I have Msft's C++ RTL, but the link to nte that you provided does not appear to work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] the link to nte that you provided does not appear to work.
Which "the link"? Re: "does not appear to work", see "tried" + "to
no avail", above.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apologies. The link wasn't. However, I did find your exefile and ran it, with this result:
debug: 0xffffffff .
MAC0: >04A1512574CA<.
MAC1: >04A1512574CA<.
user: >admin<.
pass: >Fl1bberdeg1bbet<.
getaddrinfo():
ai_family = 2, ai_socktype = 0, ai_protocol = 17
ai_addrlen = 16, ai_addr->sa_family = 2.
ai_flags = 0x00000004.
ai_addr->sa_data[ 2: 5] = 10.0.0.1
dns_resolve() sts = 0.
sock = 128, FD_SETSIZE = 64,
FD_ISSET( sock, &fds_rec) = 1.
pre-select(1). sock = 128.
pre-recvfrom(). sock = 128.
recvfrom() bc = 3.
s_addr: 0100000a .
recvfrom() addr: 10.0.0.1
41 43 4b ACK
select(1) sts = 0.
AND THAT GOT ME IN. THANK YOU! Have the # prompt and "nvram show" tells me what I need.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For others:
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Apologies. The link wasn't. [...]
I'll bite. "The link wasn't" _what_?
You might want to change that.
> For others:
Was there any actual problem with the original link provided here, or
the link on that page to the Windows executable kit?
As the web page says (and I thought that the README made sufficiently
clear), "[...] and has a command-line interface". So, yes, on Windows,
you'd want to use a Command Prompt or PowerShell window to run it.
> Solved! [...]
It's always gratifying to see credit given where it's due.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My eyes aren't good, so I could not find the link to net.exe in the page you referenced in your answer here.
However, I did a query and found your page describing it and links to the makefiles & executables. Thank you for your work.
Did. Also changed the admin login name to something random, which is one of the things I wanted to do in the first place.
I am trying to break into my wnr2000v3, but the connection is refused. antinode, will you look at a nte.exe report in PM, or should I open a new topic in that unit's forum?
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you did what, exactly? Copy+paste is your friend. I believe
that I read that older hardware might use a TCP connection instead of
UDP. Some of the other (older) programs out there might do that; mine
is UDP-only.
> [...] will you look at a nte.exe report in PM, or should I open a new
Either one should work. With a little effort, you could probably
deduce my e-mail address, or use the form at antinode.info. If it is a
UDP v. TCP problem, then I probably wouldn't care enough to do much
about it soon. (It works with all my hardware, so far as I know.)
