- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
internet speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
The wired speed from Charter from their modem is 70 but i can only get 28 from the wireless router. no updates are available according to the firmware upgrade info. i have tried most of the channels but hanging them makes very little difference
can you help
roger
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cannot really tell exactly as to why they go bad for only a few years. Though in my own experience I had one which lasted for 6 years and that was a G router.
As a recommendation, check first the wireless adapters on your network. Are these devices using 802.11a, 802.11b/g/n or 802.11ac adapters?
Will you be upgrading in the near future? Because if you do then it would be better if you get yourself something newer like one of the AC routers.
In this way, you will be able to take advantage of the speed.
You may check the list of our routers here and see what suits you.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: internet speed
Welcome to the community, @chub
What's the exact model number of the NETGEAR device?
How do you measure the speed?
Did you try reinstalling the firmware and do a factory reset on the router after uploading the firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: internet speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: internet speed
Wireless is always incomparable when it comes to wired connection. There are a lot of factors to consider when running wireless and getting the same exact speed as the wired connection will never happen. You may need to check for the distance, interference, other wireless devices that may interfere with the router, etc.
What's the wireless adapter used on your laptop? Maybe it also needs an update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: internet speed
Thanks for yoir reply.
i have had this set up for quite a while and in the past the wireless speed though not the same as wired was good enough.
I also notice that the wireless is now slow on all our devices laptops, phones and tablets etc..
when I am next there I will try a factory reset if you think that is called for and then will try to update again unless you have a better option like a new wireless router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: internet speed
It's possible that you may need a new router if reinstalling the firmware did not work.
Try to play around with the wireless channel as well and make sure to put the router in a higher place to get a better signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: internet speed
This will be the third Netgear Router i have bought, why do they go bad after only a few years?
if I need a new one that can give us the required wireles speed can you tell me what model I should get please?
Thanks for your help
Roger
- Mark as New
- Bookmark
- Subscribe
- Permalink
