dmak411
Jul 22, 2020Follower
A6100 regular lag spikes/packet loss
I have an A6100 Wifi USB running on a Windows 10 desktop, it worked fine for a month or so, then I started getting periods of lag. I tried all the obvious stuff - reboot the PC, reboot the router, run network troubleshooter, disable/renable the device, update the driver, disable power management. The router and Internet connection works fine for every other device in the house, including another PC with Windows 10. I can see the lag when I ping the router. It is completely consistent. Every 16th packet lags or times out like clockwork when this issue is happening:
>ping -t 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=28ms TTL=64
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Request timed out.
Ping statistics for 192.168.1.1:
Packets: Sent = 44, Received = 41, Lost = 3 (6% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 28ms, Average = 2ms
Control-C
^C
Any ideas on what else to try, or is my device just broken?
No RepliesBe the first to reply
