lm12abh
Feb 02, 2020Follower
Ac1200 Wireless adapter open wifi connection
Hi All,
I have a netgear wireless adapter and when I try to connect to open wifi (free wifi that requires a pop up) it doesnt connect and no pop up happens. How do I fix this?
Example. In a cafe, click on the free wifi network, nothing happens. On a normal laptop you would obtain a pop and would require to enter an email or something similar.
Thanks in advance!
Sort By
Sounds like an issue with whatever you are trying to connect. What is that? A Windows laptop?
- emarsAspirant
I have a EX6130 dual-band wifi extender (interestingly, I couldn't find this model listed in the dropdown list). I can have it connected to an open wifi which requires a login via HTTPS website, but once the setup is completed I cannot get the login page.
Tried with a Windows laptop and Android device. Usually, right after connecting to the open wifi I am automatically prompted to provide my credentials. While on Windows, the browser automatically pops up. On Android you've got to click a pop up notification, then the browser opens up.
It looks like the wifi extender is unable (or blocking) any request from the open wifi right before or during credentials are requested.
I tried a "regular" (smart) and also Fastlane setup. None worked.
Is it possible to grab the internet configuration (IP address, gateway, subnet mask, DNS, ...) while connected directly to the open wifi and use it as custom setup inside the EX6130 IP address configuration? (I am thinking of everthing at this point).
An older (and for many other reasons, crap) Belkin wifi extender used to work fine with the very same open wifi (the only one available around here...). I don't want to go back to Belkin...
You might have more luck in the right section for that device.
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
This place is for Home WiFi Adapters and Powerline, different animals.
