BretD
Sep 14, 2017Administrator
Best USB WiFi Adapter? Nighthawk AC1900 WiFI USB Adapter Model A7000
Best Usb WiFi Adapter? Nighthawk AC1900 WiFI USB Adapter Model A7000
Are you suffering from a slow connection your laptop, and finding it inconvenient to plug in your Ethernet?
Upgrade your legacy laptop or desktop to ultimate range and performance to the faster 802.11ac WiFi speeds. Simply plug into a USB port on the computer to enjoy fast, efficient data transfer, online lag-free gaming, and HD streaming. Compatible with Windows® and Mac OS®. Works with any WiFi router.
NETGEAR Nighthawk® AC1900 WiFi USB 3.0 adapter Model A7000 wirelessly connects your laptop or desktop computer to the next-gen 802.11ac technology with WiFi speeds up to 1.9Gbps. Connect the adapter to a USB 3.0 port for fast and efficient data transfer, online lag-free gaming and HD streaming, at home or on the go. Compatible with next generation WiFi devices and compatible with 802.11ac/n and all legacy WiFi devices. Powerful antennas with Beamforming+ technology boosts speed, range, and reliability of WiFi connections. This adapter includes a magnetic cradle for an easy mount on a metal surface. Connect to your router's WiFi network with Wi-Fi Protected Setup® (WPS).
Check it out on the Nighthawk AC1900 WiFi USB Adaptor A7000 info page.
Did you pick up a Nighthawk A7000 USB WiFi Adaptor? Post your review in a new thread and we may feature it in the NETGEAR Community.
TECH SPECS:
WiFi Band |
2.4 GHz & 5 GHz |
Performance |
AC1900 (600 Mbps over 2.4GHz & 1300 Mbps on 5GHz) |
Interface |
USB 3.0 |
WPS |
Supports WPA, WPA2, WPS |
Beamforming |
Beamforming+ |
External antennas |
High-gain antennas |
WiFi Analytics |
Standards |
Best performance with USB3.0; compatible with USB2.0 |
Platform Compatibility |
Windows® 7, 8, 8.1, 10 |
