× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Orbi WiFi 7 RBE973
Reply
NETGEAR A6210 WiFi USB3.0 Adapter Connection Speed Still 54Mb/s Argggh!
Ben_Binks_2012
I have installed software version 1.0.0.36 as recommended on this forum, I have set the USB Speed to 3.0 in the Advanced tab, I have disabled the NetgearUSBSwitch process from Start-up, and probably a few other things too which escape me at this hour, but I still only get a slow 54Mb/s connection speed.
After the installation of the software v1.0.0.36 the connection speed did go up to 144Mb/s and all was good, but the next start up of my PC and all back as it was.
Any suggestion would be gratefully received as I'm just about to purchase another manufacturers Wi-Fi Adapter.
Thanks in advance.
Model: A6210|AC1200 High Gain WiFi USB Adapter
Message 1 of 6
Accepted Solutions
Ben_Binks_2012
Re: NETGEAR A6210 WiFi USB3.0 Adapter Connection Speed Still 54Mb/s Argggh!
Hi
Sorted the issue with the USB2 port speed last night by uninstalling Genie and the drivers for the A6210 manually. Then used the standalone driver pack.
T
@JamesGL wrote:
Hi Ben_Binks_2012,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
hanks
Model: A6210|AC1200 High Gain Antenna WiFi USB Adapter
Message 6 of 6
All Replies
JamesGL
Master
Hi Ben_Binks_2012,
Uninstall the driver with Genie and try installing the standalone driver.
Message 2 of 6
Ben_Binks_2012
Thanks but I have already tried this numerous times. Like I said, I had everything done and working, shutdown the PC, started back up a while later, and the message came up again telling me the device can perform faster.........so I checked and sure enough 54Mb/s. Wounded haha
Message 3 of 6
JamesGL
Master
Hi Ben_Binks_2012,
Do you have another computer? Try to install it and check if the same error.
Message 4 of 6
JamesGL
Master
Hi Ben_Binks_2012,
Message 5 of 6
Ben_Binks_2012
Hi
T
@JamesGL wrote:
Hi Ben_Binks_2012,
hanks
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 10459 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
