× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Netgear WNCE3001 and Tivo Mini
nsinha
I've connected my WNCE3001 to a tivo mini because i cannot run new networking cables between rooms in my apartment easily or cheaply. I have no problems with live television but cannot consistently connect to the shows recorded on my Tivo Roamio without having to power cycle my tivo at least a couple of times a day. It is probably a Tivo limitation but is there a way we can circumvent it by changing some configuration settings either for the WNCE3001 or for my router which is a Netgear WNDR4500 v1 ?
Model: WNCE3001|Universal Dual Band Wireless Internet Adapter
Message 1 of 7
Accepted Solutions
nsinha
Re: Netgear WNCE3001 and Tivo Mini
Thanks. So confirmed that the Netgear WNCE3001 cannot be used with the current Tivo Mini version.
Message 7 of 7
All Replies
JamesGL
Master
Hi nsinha,
The only setting you can change on the router is the channel or mode but I don't think this will help as it might be a limitation of the TiVo as what you have mentioned.
Message 2 of 7
nsinha
Yes unfortunately.
When i called Tivo, they mentioned that there may be a wireless lag (even if it is a tenth of a second) between the wireless signal and the wired one that may be causing their systems to not be able to work together. I am going to see if connecting the main tivo module wirelessly also instead of via a hard connection will help with the synchronization... since now both modules will essentially be connected to the router wirelessly. I will provide an update after testing this later today.
Message 3 of 7
nsinha
That did not work. It would have been too easy.
So its back to power cycling before i use the tv connected wirelessly if i am not watching live content or the smart apps or unless someone else has a suggestion.
Thanks
Message 4 of 7
JamesGL
Master
Hi nsinha,
I would suggest try to connect both on wired connection since TiVo mentioned that it might be because of the lag on wireless.
Message 5 of 7
JamesGL
Master
Hi nsinha,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 6 of 7
nsinha
Message 7 of 7
Discussion stats
  • 6 replies
  • 7830 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
