patrick2007
Jul 27, 2020Tutor
ReadyShare dissapeared
Readyshare was working and it suddenly disappeard.
Sort By
- Blanca_ONETGEAR Employee Retired
Hi patrick2007
Welcome to NETGEAR Community!
Please provide the model number of your NETGEAR router and firmware version.
How do you access Readyshare?
Are you trying to access it in Windows and/or Mac?
Blanca
Community TeamI'm tying to access via Windows.
Hi patrick2007
Blanca
Community Team
That is correct. I was transfering some files from the computer to the readyshare and it froze and then it dissapeared.
Can you explain what you are doing?
The A7000 is a USB adapter that provides wifi for your PC. It does not support ReadyShare in its own right.
What provides the ReadyShare stuff?
A Netgear router of some sort?
Is this Readyshare disk storage? A printer? Something else?
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
