RBLampert
Jul 21, 2022Aspirant
"Unusual" Runtime termination error message
I've started getting the error message in the attached image when I start my computer. Everything seems to be working properly, though. I'm running 64 bit Windows 10. Is this something I need to be concerned about or try to fix? If fix, how?
Thanks.
Fetch the "latest" drivers from WNA3100 Software Version 2.2.0.4 (Supports Win8/8.1), uninstall the existing WNA3100 adapter software and application from your system as advised, remove the USB adapter, and restart the system. Install just the standalone driver kit. Plug the WNA3100 USB adapter. Wait until the adapter is recognized. Use the standard Windows way for configuring a wireless network. No fancy utilities required to be run.
Sort By
- jme60Aspirant
I'm also having this issue although my error message indicates the problem is with v2. I'm trying to see if this is what is causing my computer to run slower. It definitely could be something else, so I was trying to eliminate the runtime error. Any issues with computer speed because of this error?
You have joined in on an existing conversation that may or may not have anything to do with your problems. (Hard to tell with no information from you on your Netgear device.)
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide.Standalone WNA3100_SW_V2.2.0.2_Setup_STALONE.zip kit.
For the WNA3100M Software Version 1.2.0.9 also follow the uninstall procedures, and install only the Driver Only: WNA3100M_Standalone_Driver_Setup_V1.0.0.28.exe kit.
No need for installing the crappy tools on "modern" Windows systems, starting from Windows 8.
- RBLampertAspirant
Done. Thanks. We'll see if that made a difference, since I was already running version 2.2.0.4.
The difference is that only drivers ae installed, no additional tools, utilities, and runtime.
