- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Flash programming procedure
- Mark as New
- Bookmark
- Subscribe
- Permalink
Letter of Volatility for JGS516v2 says to Use flash programmer to clear internal Flash but does not list the step. Can anyone help me with the steps to use flash programmer to clear internal flash of this switch ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Prakas,
I inquired your concern to the higher tier of NETGEAR Support and just got a feedback. As per the higher tier of NETGEAR Support, the step that you are referring to is not applicable for customers. Flash programmer is not available to be used by customers.
If ever your concern has been addressed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Prakas,
DaneA
