- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
102 with mixed size disks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
After a lot of years a 2TB disk is failing. It turns out to be cheaper to upgrade to 3TB. Can I mix a 2TB with a 3TB? Let raid do its magic with redundancy and then upgrade the second disk to 3TB? Is this a rational strategy?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tenforty wrote:
Hi,
Thanks
Yes, this works (and is called "vertical expansion").
One caveat is that the array isn't protected during the resync. So it is important to have a backup of the data before you manipulate disks in the array.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tenforty wrote:
Hi,
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 102 with mixed size disks
And take a look at your potential future use. It's a lot cheaper to go bigger now than go small and have to completely replace again later.
2 x 4TB (or even bigger) now instead of 2 x 3TB now and another 2 x 4TB later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree - it's cheapest to plan ahead, and not upgrade too often. The sweet spot for $/TB starts at about 4 TB at the moment, and seems to be moving up. And at the moment a 4 TB ironwolf costs $100 (US Amazon) - the 3 TB model costs $97.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Very helpful responses. Thank you all very much.
