Stalin66's avatar
Stalin66
CPU temp on PRO 6 (pioneer edition) on os 6.0 - 6.4.1
Hellow all!
I upgraded the OS from 4.2.28 to 6.4, and I have significantly raised the temperature of the CPU. Previously it was 35 C, now - 60! It very hot... Now, the fan speed SPU (PWM Noisebloker 120 mm) is not higher than 950 rpm. Older, on 4.2.28 i see 1050 - 1200 fan speed.
How can I increase the speed of my fan?
    • Stalin66's avatar
      Stalin66
      Yes, all standart unit without memory (4Gb) and CPU fun (I'm installed Noiseblocer 120 mm - very cool, 30-37 C on 4.2.28). I want this temp on OS 6 !)
      No new programm - only transmission and system info
  • I have a Pro 6 with a upgraded X3230 CPU...had no problems with CPU temp spiking until 6.4.1...CPU temp climbs 25C degrees when I run scrub on my volume.
    • Equinox1's avatar
      Equinox1
      Guide
      walshlink...just for my curiousity. What were your normal temperatures, and with what OS version?
      And what do you have now?
      • walshlink's avatar
        walshlink
        Luminary
        6.4.0 sat at 48C idle...did not really climb much if at all during normal usage
        6.4.1 sits at 51C idle...have not paid attention to temps for normal usage, but if I scrub volume CPU temp climbs 25C in 3 mins...not sure that is even possible to climb that fast...
        Model: ReadyNAS Pro 6 (RNDP6000-200)
        Upgraded CPU: Intel Xeon X3230
        Memory: 4 GB
        HDD: 4x Hitachi 2TB
        Upgraded System Fan: Noctua NF-P12 PWM - 120mm
        Upgraded CPU Fan: Noctua NF-R8 PWM - 80mm
