Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue with new beta 6.2.3-T1652
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
05:40 PM
2015-01-14
05:40 PM
I tried upgrading one of my devices today from 6.2.2 to 6.2.3 beta. This is a Pro 2 which I have been running on OS 6 since early 2014. The upgrade seemed to go fine and the system rebooted and I was able to reconnect, but soon after connecting to Frontview I started getting these messages:
Connecting to ReadyNAS Admin Page...
it would sit at that screen as the progress bar would go completely across without going back to the Frontview. I was still able to connect via ssh and rebooted the device. I found that Frontview would work for the first 30 seconds to maybe 2 minutes before I would get the connecting message again.
I was able to get frontview to work long enough after a reboot to downgrade back to 6.2.2 and everything seems to be working fine again. Just wanted to give a heads up in case someone else is seeing something similar or was thinking about trying this beta.
Jeff.
Jeff.
Message 1 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-15
11:30 AM
2015-01-15
11:30 AM
Re: Issue with new beta 6.2.3-T1652
+1
Upgraded last night, same symptoms this morning. I don't have SSH enabled however so I'm a little worried about how I could implement any forthcoming fixes...
Message 2 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-15
05:55 PM
2015-01-15
05:55 PM
ahpsi, your issue appears to be related to Transmission.
cerjzc, do you also have Transmission installed.
There is a known issue with 3.00.6: http://www.readynas.com/forum/viewtopic.php?f=153&t=76617
Message 3 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-15
06:54 PM
2015-01-15
06:54 PM
mdgm,
Thanks for the response. I do have Transmission installed on my Pro 6 which is running 6.2.2 and is working fine. On the Pro 2 I do not currently or have never used Transmission. The Pro 2 is the only one that I have tried beta 6.2.3 on and like I said yesterday I was able to back it down to 6.2.2 so currently I'm fine. I will take a look at the thread you provided though.
Thanks,
Jeff
Thanks,
Jeff
Message 4 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-15
07:00 PM
2015-01-15
07:00 PM
I wondered if Transmission could have caused your problem too. I guess something else must have caused your issue.
Message 5 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-15
07:20 PM
2015-01-15
07:20 PM
cerjzc or ahpsi did your I.P. address change?
One of our engineers has found this problem independently and diagnosed it as occurring sometimes when the I.P. address has changed after a reboot.
Message 6 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-15
07:41 PM
2015-01-15
07:41 PM
No I don't believe it changed. I have it set to static and if I recall correctly it showed the same in Raidar when I tried to connect. And I could connect right after the reboot and move around the frontview pages for close to a minute before that message about "Connecting to ReadyNAS Admin Page..." came up and after that any further attempt to reconnect would go directly to that connecting screen with the progress bar moving across. I did a complete power off and disconnected the power cable to make sure I got a clean boot as well, but it acted the same. Initially I could connect and do actions, but soon it would fail. In fact I wasn't sure I would be able to get to the firmware loading page, but I had just enough time to browse to the 6.2.2 image and upload it before it failed.
Jeff
Jeff
Message 7 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-15
09:13 PM
2015-01-15
09:13 PM
Just as an update I checked the frontview log and found that during the time I had 6.2.3 installed it was logging this over and over again:
If there is further information or logging that might still be available I can try to track it down.
Jeff
Wed Jan 14 2015 17:57:36
System: ReadyNASOS background service started.
Wed Jan 14 2015 17:57:34
System: ReadyNASOS service or process was restarted.
Wed Jan 14 2015 17:55:00
Wed Jan 14 2015 17:54:59
System: ReadyNASOS service or process (readynasd) was restarted.
Wed Jan 14 2015 17:54:33
Wed Jan 14 2015 17:54:32
Wed Jan 14 2015 17:54:06
Wed Jan 14 2015 17:54:05
Wed Jan 14 2015 17:53:39
Wed Jan 14 2015 17:53:38
Wed Jan 14 2015 17:53:11
Jeff
Message 8 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-15
09:15 PM
2015-01-15
09:15 PM
If you download the logs do you see anything in readynasd.log that may indicate why it restarted ?
Message 9 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-15
09:51 PM
2015-01-15
09:51 PM
mdgm,
The readynasd.log does appear to have quite a bit of information around that time. Is it possible to attach the log or send it to someone that might be able to look at it. I can cut and paste it here if needed, but there are probably a 100 or more lines from when 6.2.3 was installed and the readynasd process was restarting over and over again.
Jeff
Jeff
Message 10 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-16
02:42 AM
2015-01-16
02:42 AM
There is a Sending Logs link in my sig.
Message 11 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-16
03:28 AM
2015-01-16
03:28 AM
The readynasd.log file has been emailed.
The upgrade was done on the 14th at 17:30.
Thanks,
Jeff
Thanks,
Jeff
Message 12 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-16
03:39 AM
2015-01-16
03:39 AM
Can you send in the full logs zip file?
Message 13 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-16
03:45 AM
2015-01-16
03:45 AM
Full logs have been sent.
Jeff
Jeff
Message 14 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-16
03:49 AM
2015-01-16
03:49 AM
Hi cerjzc think the issue you encountered is already addressed internally. So you may wish to try Beta 3 once that is made available.
Message 15 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-16
03:51 AM
2015-01-16
03:51 AM
Ok sounds good. I will just keep an eye out for the next release and see about giving it a try.
Thanks for taking a look. Just wanting to check to make sure I assume there would be a way to install the firmware via ssh if frontview is not available?
Jeff
Jeff
Message 16 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-16
03:53 AM
2015-01-16
03:53 AM
Yes
# cd /root
# wget http://www.readynas.com/download/beta/readynasos/6.2.3/ReadyNASOS-6.2.3-T1652-x86_64.img
# echo /root/ReadyNASOS-6.2.3-T1652-x86_64.img > /etc/.flash_update
Message 17 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-16
03:54 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-16
03:56 AM
2015-01-16
03:56 AM
I could be wrong about it being fixed, but it looks like it should be easy to reproduce and our engineers can use more verbose logging to help them to pinpoint the cause of the issue.
I think the entry I saw around the crash may not be related to the problem.
Message 19 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-22
06:04 PM
2015-01-22
06:04 PM
mdgm,
I see that Beta3 has been released. In reviewing the release notes I'm not sure if the issue I was seeing was resolved or not. Do you think it is worth trying it or should I hold on and stick with 6.2.2 for now.
Thanks,
Jeff
Thanks,
Jeff
Message 20 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-22
06:06 PM
2015-01-22
06:06 PM
Try 6.2.3 beta 3. Our engineers saw the issue too internally. It should be fixed in Beta 3.
Message 21 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-23
12:34 AM
2015-01-23
12:34 AM
Just to close this issue out. The 6.2.3 beta 3 did appear to resolve the problem. I let it run for several hours with no issues and then on my Pro 2 I did go ahead and upgrade it to the newer 6.3.3 beta and it also appears to be working fine as well.
Thanks,
Jeff
Thanks,
Jeff
Message 22 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-24
11:31 AM
2015-01-24
11:31 AM
You might want to consider upgrading to 6.3.3 beta, I have been running that on Ultra 4 plus with no problems
Message 23 of 24
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-27
03:01 PM
2015-01-27
03:01 PM
6.2.3 beta 3 fixed mine also. Haven't tried 6.3.3 yet and unsure if the Transmission bug affected anything. Backed up the system to an NVX but I forgot about limiting what it backed up and it filled the NVX up with snapshots (I believe). In any case the beta worked for me.
Thanks!
Thanks!
Message 24 of 24
