× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NAS not showing under Network again after update to 6.4.2
ndverge
I recently updated the firmware of NAS device. after update, the NAS device not visible on the network. But I can type the name on the run command and access. But i want the  nas device to be visible on the network so that access it easily and fastly.
thanks
Message 1 of 15
Accepted Solutions
ndverge
Re: NAS not showing under Network again after update to 6.4.2
I just switch off the and on our 8-port switch. then the NAS drive is visible to all the computers in the network. thans who supported me.
Message 13 of 15
All Replies
JennC
NETGEAR Employee Retired
Hello ndverge,
How about the mapping the NAS' hostname and assign a drive letter for it?
Message 2 of 15
ndverge
No. When i have to configure new computers that may be a problem with those new users who are not in our company.
Message 3 of 15
Guru
Both my RN102 and RN202 show up under network (on Windows 10) and both are running production 6.4.2.
Unfortunately showing up under network has been hit-or-miss for years (and I think is the same with all NAS).  Adding a network location in file explorer is one workaround, putting a shortcut on the desktop is another.  I understand this is extra work when configuring a new PC, but I don't think there is a silver bullet to fix this.
Message 4 of 15
ndverge
I think its better to downgrade to 6.4.1 again.
Message 5 of 15
Guru
You certainly can.  It might not help though.
Message 6 of 15
ndverge
You are saying that even if i downgrade the firmware, the problem will be remained still?
Message 7 of 15
mdgm-ntgr
No, he's saying that it is a possibility that it might remain. You can try downgrading to 6.4.1 and find out, if you want. Let us know of the outcome.
Message 8 of 15
ndverge
I downgraded. but no any chance to win the war. Still the NAS device is missing in the network list.
what to do?
Message 9 of 15
Guru
If this is with Windows 10, I think there might be some fixes coming from Microsoft (at least I recall seeing a post to this effect on another thread).
Message 10 of 15
ndverge
No. It's Windows 7. ????
Message 11 of 15
Guru
Well, as I said earlier this is very hit-or-miss (and has been for a long time).  It's hard to tell if its a bug in Linux or Windows.  You can waste a lot of time trying to wrestle this to the ground.
One thing to check is the workgroup settings on the NAS and PC - they should match.
Message 12 of 15
ndverge
Message 13 of 15
JennC
Hello ndverge,
It must be the network is becoming to strict, firewall blocking it probably.
Message 14 of 15
Guru
It could also be an issue in the switch.  It has its own layer-2 routing tables, and might not be distributing the discovery traffic correctly.  Rebooting the switch clears the tables, and it broadcasts everything until it rebuilds those tables again (looking at the mac addresses that are active on every port).
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 2869 views
  • 0 kudos
  • 4 in conversation
Announcements
