- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Pro6 DiskTrays with round button
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Pro6 and several Ultra2, all bought second hand. Pro6 came with older model disktrays which have a round button which needs to be pressed to make the handle pop-up. Ultra2's cam with disk trays with a slider to make the handl pop-out and another smaller slider to lock the first.
I have problems all the time with the Pro6 disk trays, the buttons getting stuck, tried WD40 on those buttons with poor results.
I noticed those trays also have a lock slider but somehow is on the other side of the handle (inside, toward the HDD and blocked by it). I wonder what is the idea, how is the lock slide supposed to be engaged or disengaged if is on the inside ? Do I miss anything ?Doing something wrong ? Is it a known problem ? Is there a solution or tricks to solve it ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Pro6 DiskTrays with round button
It'
s flat-out a bad design, which is why it was replaced. Forget the buttons and use a small screwdriver or bent paper clip to release the trays. Here's a video somebody made: https://www.youtube.com/watch?v=zKczCPiqc-4 .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow, thank you, I was sure there are many people having the same issue and somebody should have found a workaround. I also mucked around with the paperclip and the hole in the middle of the button with no results like the person in the video but the hole next to the blocked hole worked like a charm.
