× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Ready NAS 104 Locks Up (6.4.1)
Triteleaf
Hello all!
At some point that I haven't nailed down, my ReadyNas104 (6.4.1) hangs completely. All front lights get stuck solid, the screen continues displaying whatever was on it at the time of the hang, and the NAS begins refusing all network access, including SMB, AFP, HTTP, Anything.
The only solution is to unplug it and plug it back in, triggering a volume resync, which usually fails and locks up again around 22% or so.
I've performed an OS Reinstall, Complete Factory Reset, and Have tried disabling bit rot, and the antivirus scanner.
The NAS is running no apps, has one user (admin), and has 2 shares, one containing disk images, the other media files.
Both shares are using SMB, AFP, and NFS.
The log files are availible here.
Any help you could give would be appreciated.
Message 1 of 6
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: Ready NAS 104 Locks Up (6.4.1)
Thanks for the logs. Please try ReadyNASOS 6.4.2 (RC1)
There is a known RAID-5 issue you may be running into.
Looking at your logs also it looks like you still have anti-virus enabled.
Can you see if the system still locks up if anti-virus is disabled and you update to 6.4.2-RC1?
Welcome to the Community!
Message 2 of 6
All Replies
mdgm-ntgr
Message 2 of 6
Triteleaf
Thanks for the prompt response. I'll update straight away, and I'll fill you in on the results.
Message 3 of 6
Triteleaf
Well, The new firmware is in, and there hasn't been a lockup, so I'll assume the issue is solved.
The volume resync seems to be taking longer than normal, but at least it's making progress.
Message 4 of 6
stijnpeeters
I didn't have AV on and still my nas locked up at FW 6.4.1
Message 5 of 6
BrianL2
Hi stijnpeeters,
Welcome to the community!
Kindly send us a copy of your device logs and try the same RC Firmware (Beta) in your unit. Then tell us if there's still a lock-up issue.
Kind regards,
BrianL
NETGEAR Community Team
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3030 views
  • 0 kudos
  • 4 in conversation
Announcements
