- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 104 No Volume Exists
- Mark as New
- Bookmark
- Subscribe
- Permalink
Greetings: I was having an issue with my ReadyNAS 104 [see: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-104-Inaccessible-ReadyNAS-...] which I thought I'd resolved.
I replaced the failing drive #4 and the NAS recognized a new drive had been inserted.
I upgraded to the latest firmware (6.10.8) and rebooted to start the RAID rebuild, but the NAS is no longer seeing any volumes.
I removed the new drive and rebooted again, still no volumes.
Any suggestions/assistance appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 104 No Volume Exists
It would have been better to wait for the resync to complete before you updated the firmware and rebooted.
Do you still have an up-to-date backup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did try waiting for the new drive to rebuild, but the NAS just sat there inactive.
After a day-and-a-half, I decided to try the reboot.
I don't have a full back-up, but I was able to back up my most important files to a USB.
It's looking like I may have to create a new volume and start reloading the files I have backed up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you decide to do that, then I suggest doing a factory default, which would rebuild everything.
You can do that either from the boot menu, or from system->setting in the NAS web ui.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for that suggestion.
I may just begin with the single 6TB drive I bought as a replacement, then add additional 6TB drives until all 4 bays are filled.
I ran a diagnostics check, and it looks like my other drives are also failing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That looks like it may only be Disk 2 failing. The others are for volumes that include it.
What model drive did you add? If it's a SMR model (WD Red and many desktop models), then that would be the reason for the lengthy re-sync. But it's also reason that you don't want it to be a part of your new volume.
It could be the failing drive that was causing the long re-sync, but you don't seem to have enough errors recorded to give that much trouble.
