× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 214 Won't Restart/Shutdown
Buxton
Apprentice
Hi,
I have a bit of an odd problem and admittedly you can only reproduce it after doing something quite specific. So if I have a .mkv file in one Share and I connect to the NAS via Windows Explorer and copy the file to another Share on the NAS the file transfer hangs immeadiatly and locks up Explorer and only a system restart can recover the system. Sounds like a PC issue right, but then when you go to the admin page for the NAS through a browser, the entire system is fine EXCEPT it can't then load the directory where you tried to copy the file to.
I left it a while then went back and nothing changed, so I went for a restart to see if i can access the directory again, however the power light flashes on the NAS and the LCD says restarting however the box stays active with all Shares/Apps availible and the admin page reloads back to its normal state. I don't want to button the unit unless you know a "safe" way. Could this be a bug in the ReadyNAS OS as its happened even after i've completely reset the unit (including disks/data). Perhaps the Beta build might help to force the restart and resolve the bug?
Any help would be appreciated, here are my specs; ReadyNAS 214 4 x 3TB WD Red, X-RAID. ReadyNAS OS: 6.6.1
Model: RN21400|ReadyNAS 214 Series 4- Bay (Diskless)
Message 1 of 24
Buxton
Apprentice
Re: ReadyNAS 214 Won't Restart/Shutdown
UPDATE: I after trying to switch off apps to rule out them messing around with files and trying to set a scheduled restart to see if that would work I now cannot access the admin page at all, it just times out and reloads. I can still see it in RAIDar and can browse to it via IP address but not through hostname and I cannot SSH either. Any ideas?
I'm tempted to pull the power now as the logs don't show anything odd and even a restart command from the app didn't work either.
Message 2 of 24
Buxton
Apprentice
UPDATE 2: I decided as I took a backup not long ago I would just pull the power and the system has come back up and is speedy fast again which is good. However I think im concered with the fact that today and a few weeks ago (when my array completely died) it was both the result of asking the unit to restart and then it wouldn't.
My logs don't show a problem with SMART or anything so could it be the NAS itself being faulty? And should I try restarting it again now to see if it can point blank?
Message 3 of 24
Guru
What firmware are you running?
One option (brute force) is to do a factory reset, and rebuild the NAS from scratch.  Then restore the data from the backup.
If the problem is still there, then it could well be the NAS hardware.
Message 4 of 24
Buxton
Apprentice
Hi, thanks for the reply it's 6.6.1. I did do a factory reset last time after I had to pull the power and it destroyed the array after not booting and it seems like it's just happened again.
Would you say if I can't restart it now then it would be worth an RMA, or maybe a firmware upgrade to beta?
Message 5 of 24
Guru
You could try contacting support and ask about an RMA.
One variation on the reset - if you have a scratch disk, you could power down, remove the drives (labeling by slot), and install the scratch disk.  Then see if the scratch disk system behaves the same way.
Message 6 of 24
Buxton
Apprentice
I might give that a whirl with a spare I have actually, I did get the unit on Amazon so I'm sure they'd RMA quite happily if asked. I'll see what my testing throws up.
Message 7 of 24
mdgm-ntgr
NETGEAR Employee Retired
Can you provide the full system logs (see the Sending Logs link in my sig)?
Message 8 of 24
Buxton
Apprentice
Hi,
I've just sent the logs in. I also just tried shutting down the system from within the UI which worked, so it seems that the issue with the unit locking up only occurs after transferring a file between Shares from Windows.
Message 9 of 24
mdgm-ntgr
The logs you sent are incomplete and missing the most important log the journal.
If you disable the anti-virus service and reboot does that make any difference?
Message 10 of 24
Buxton
Apprentice
Apologies, where would I find the journal? Those logs were taken from RAIDar application last night however I do have some I took from the web UI this morning if that would contain it?
I can try to reproduce the issue with the locking up and not restarting with the antivirus service turned off if you want, would it be prudent to also have any apps switched off at the same time?
Thanks
Message 11 of 24
Guru
@mdgm-ntgr wants the full log zip file.
Message 12 of 24
Buxton
Apprentice
Hi, I did send through the complete .zip I got from RAIDar.
Message 13 of 24
Guru
Maybe get another one (perhaps from the web ui log page), and resend.
Message 14 of 24
Buxton
Apprentice
I had a look at what I pulled from the UI and it is different so i've sent those logs from this morning across. Cheers for the help everyone.
Message 15 of 24
Buxton
Apprentice
Out of curiosity has anyone tried the beta release of ReadyNAS OS? Is it relatively stable?
Message 16 of 24
jak0lantash
Mentor
I'm using that... on my backup NAS. But as usage can differ, it's difficult to rely on other people's experience with a beta F/W. By nature, it's wasn't fully validated in QA, so bugs, more or less random, are possible.
Message 17 of 24
mdgm-ntgr
It looks like you haven't tried turning off the anti-virus service yet?
Message 18 of 24
Buxton
Apprentice
Hi,
I've tried with the Anti-Virus service switched off and I was able to reproduce the issue so I have sent in new logs. As soon as you try to initiate a file transfer between Shares from within Windows the copy fails and immeadiatly the NAS starts to slow down with access to the Admin page being the first to be unavailible.
Thanks
Message 19 of 24
Skywalker
NETGEAR Expert
@Buxton, I've been trying to reproduce your issue, but I've been unable to so far.  Are the two shares you are copying between on the same volume?  What version of Windows are you using?
I've been testing with Windows 10, and with both shares on the same volume, copying a set of about 30 ~1-2GB files between shares.
Message 20 of 24
Skywalker
NETGEAR Expert
Message 21 of 24
Skywalker
NETGEAR Expert
BTW, here's a little trick for copying files between shares.  If you log in to the NAS as the "admin" user from Windows Explorer, you should see a share called "data" (assuming your data volume is still named "data").  If you copy files between the share directories under the "data" share, it will happen almost instantly, and the copies will consume no additional space.
Message 22 of 24
Buxton
Apprentice
Hi, Yeah the two Shares are on the same volume called "data". One is a Transmission share and the other is a share for videos. I have the volume mounted as a network drive in Windows using the admin credentials, however it looks like Windows does try to copy it across as it gets to 12% then freezes and can even crash Explorer.
Message 23 of 24
Buxton
Apprentice
Hi,
Another update, I woke up this morning and the NAS was completely unresponsive, no SSH, no Admin page or RAIDar so I had to hard reboot the device. It came back up completely fine though and now works OK but i'm unsure to why its doing it as the journal doesnt show anything which could have caused it, in fact the logs run right up to the reboot.
The only thing which is there which wasn't the other day when I sent logs in, is a loooot of this:
Mar 20 08:38:32 NAS minissdpd[2921]: sendto(udp_notify=6, http://192.168.1.125:10000/nasService.xml): Invalid argument
Is that common?
Message 24 of 24
Top Contributors
Discussion stats
  • 23 replies
  • 6171 views
  • 0 kudos
  • 5 in conversation
Announcements
