- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 6 Ultra RNDU6000 Stuck on "ReadyNAS"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I'm hoping not to have lost all my data.
I haven't turned on my RNDU6000 in a while, the last time I did was to do an upgrade..
It is now stuck on the "ReadyNAS" display. After doing forum research and reading similar experiences, I have done the following:
1) Soft reset using Backup Button.
2) Hard reset using the reset switch with paperclip.
3) Replaced the RAM.
4) Removed hard drives
5) Created recovery USB and attempted to boot it. It doesnt appear to boot at all.
6) Tested all voltages on the power supply, all voltages are within spec for a standard PSU.
Any further suggestions would be much appreciated.
Thanks, Mark
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 6 Ultra RNDU6000 Stuck on "ReadyNAS"
Was the boot menu responsive when you tried these steps? Or was the LCD stuck on ReadyNAS
If it was responsive -
- Do you really mean an OS reinstall for (1)?
- Do you really mean a factory default for (2)?
Check pages 28-29 here if you need a refresher on the boot menu options
The factory default would have destroyed your data if you did it successfully with the disks in place.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stephen,
Thanks for the quick reply.
There was no response to 1) or 2), the LCD remained stuck on ReadyNAS.
I removed the hard drives with the data on before doing any of the resets. I should have labelled that as the first item in the list.
The attempts to do a recovery via USB drive met with no response at all. It remains stuck on "ReadyNAS" screen. There are no network lights when the RJ45 cable from switch is plugged in. Its simply not booting at all.
I checked voltages as this was a common problem. I remember a couple of short power outages while the device was on and running, but don't remember if this is when it failed as I hadn't used it for a while.
There was evidence of roaches inside (some droppings on motherboard which I carefully cleaned off.
I'm beginning to suspect a hardware failure on the motherboard, but was hoping that someone may be able to assist with a VDP wipe, I hear that may be what is corrupt. Apparently the VDP is an encrypted file in the boot flash that contains information on the model and serial number and only Netgear can create.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then they do nothing. The OS is on the disks, and the NAS boots from the disks. The OS-reinstall does a partial reinstall of the OS onto the disks (and changes the password and some other settings back to the default). The factory default formats the disks and does a fresh install of everything. Both require the disks to be installed.
Did you check the PSU voltages when the PSU was under load?
The USB recovery process is finicky about what drives it detects. Older ones tend to work better. Also, if you have one with a LED that shows access, that can be helpful.
And only Netgear can re-create it. There is no support for your NAS anymore. Mods used to do it as a courtesy, but they haven't offered to do that for some years.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you convert the NAS to OS-6? Or is it still running 4.2.x firmware?
Are you interested in other options for off-loading data?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB has already covered most of the bases.
All the NAS needs for it to display "ReadyNAS" is 5V, and not even very well regulated 5V.
Testing a disconnected power supply is a marginal, at best, test. Either test under load, or try another supply. A standard ATX12V supply can be used externally to see if that's the problem.
An issue with the VPD file should not prevent you from getting to the boot menu, but other issues with the flash memory may. A USB recovery is the only possible solution for that, and then only works if it's just corrupt, not a hardware issue. The NAS is very picky about the USB drive used for recovery. The smaller and older, the better. I've had good luck with the cheap 8GB ones you find on eBay and Amazon.
A good tool for helping figure out what's wrong is a VGA cable. Your Ultra6 has a VGA header, so you'll need a cable that goes from that to the standard DB-15. Unfortunately, they are becoming hard to find. You need the kind that goes from a 16-pin 2-row IDC header (with one pin missing) to the standard one. I last purchased from solutioncables.com, and they still have them, both direct and on eBay.
There are a number of ways to recover your data, but they depend on whether you've updated to OS6 or not. It depends on whether the volume is corrupt or not, too, but since it failed while power was off, it's likely it's intact.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Sandshark,
Thanks for your reply.
The power supply was tested under load, connected to the mainboard with a spare drive installed. All pinout voltages appeared within spec as per standard ATX pinouts.
Thanks for the tipabout the USB device, I will try some older ones.
Re.and VGA header, its been a long time since I was in the business of repairing PC's, but I have a friend who does this for needy people and he has a garage full of spares, I'm sure he will have a 6 pin IDC to VGA connector as they were used on a number of motherboards.
I'll see how I go, I'm thinking its the motherboard as there was a bit of insect waste on it.
Thanks, Mark
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same issue and go it to the point where it boots and I see the front view but cannot do anything with it. Windows share can see and use the shared drive as normal though. (Since no frontview, cannot set permissions for the folders)
Apparently OS6 doesn't need the VPD file anymore. If you can get into TTL through tech support mode you can try the R4toR6 upgrade. There are 2 files, 1 "prep" and 1 of the actual OS. The prep you'll have to do manually using TTL, the OS file can be flashed using the USB+hold backup button while powering up.
To manually apply the prep bin file, get 7zip and extract the contents. Run the command (I forgot what) from the init file.
Rename the R4toR6 file to the normal firmware filename for OS4 and use the USB recovery tool for OS4 to load it onto the NAS. After turning on and holding the backup button, count to 3 after you hear the fans spin down a little. After 2-5min max, it should turn itself off. If it hasn't then the USB didn't work
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since updating to OS6 destroys the OS4.2 data, that's not a solution when someone is trying to recover their data..
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think there will be more and more of these cases popping up. There should be an automated VPD signing service from Netgear now that mods no longer have time to do this. What a shame...
OP has the option to put all drives into a linux tower and run "R-Studio for Linux" to recover files. But if the VPD has exploded, then the ReadyNAS is another headed for the garbage pile. Unless you want to short/hold down the backup button and keep a USB in there the whole time
