- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Stop running resynchronisation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi.
I have some question about resynchronisation on ReadyNAS 4312, OS 6.9.6.
On the 15 november 2022 after an an unmanaged reboot of the nas, some errors on disks sda2 pops on the logs.
A resynchronisation was started automaticly.
Actually on 20 december 2022 the resync is still running and freezed on 75.03% since 3 weeks.
Time left 406121:54:00 ......
Since the 15 november no data pops on the logs via the web page.
Our NAS is on raid 6 with 12 drives with x-RAID 2.
About 56 To of spaces on the volumes and only 10 To used.
My question are the following.
This resynchronisation is a reconstruction of the volume, isn't it ?
Why does she start alone with a faulty disk and no disk replacement ?
Can we stop this running resynchronisation with no risks ?
Can i replace the faultly hard drive in hot swap just after stopping the resynchronisation ?
Can i see the logs of this resync by command line ?
What is the best process to perform disk replacement in this case with the minimum of risks.
Thanks a lot for your answer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Stop running resynchronisation.
It's a reconstruction of one disk in the volume (using the parity+data blocks on the other disks).
Generally no, the volume will remain degraded if you do. If you know which disk is causing the problem, then it would be safe to replace that disk - especially since you are running RAID-6. But it is not completely without risk.
Downloading the log zip file is probably the best place to start. mdstat.log should give some info on which disk is resyncing. system.log, kernel.log, system-journal.log should have some information on disk errors.
I normally recommend hot-swapping (NAS running). You do need to be careful to identify the correct drive.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi and thank you for your feedback.
I will replace the drive tomorrow (hot swap).
For the logs since the disk is in error, we cant donwload logs from the web page. We will check from command line.
Next week for the feed back
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried? The logs are stored in the OS partition, which is replicated on every disk. The web page performance is slower during a resync, but it should still work.
If you use the command line, then for most logging events you need to use journalctl.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi.
The nas was completly unresponding and the download off logs never works. The reboot doesn't work too.
After the disk replacement the logs download works. Now the volume is degraded and run a clean.
