Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Stuck at "Testing disks"
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-25
11:03 AM
2011-08-25
11:03 AM
Hi, i just got my ReadyNAS Ultra 4 and have installed 4 disks (Western Digital Caviar Green) but when I start up it stopps at "testing disks".
Any suggestions?
Any suggestions?
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-25
04:30 PM
2011-08-25
04:30 PM
Re: Stuck at "Testing disks"
Are the disks brand new? Or are they used?
Sounds like one of the disks may have a problem. Could you try turning the NAS off, then booting with just one disk installed, update to the latest RAIDiator (currently 4.2.17: http://www.readynas.com/RAIDiator_x86_4_2_17_Notes), reboot when prompted to install the update, verify update completed successfully then power down, insert other disks and do a factory reset (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu)?
If it still doesn't work, try the "Disk Test" boot option (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu) and if that doesn't work, hook the drives up to a SATA port on your PC and test them using manufacturer's diagnostics.
Welcome to the forum!
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-26
04:33 AM
2011-08-26
04:33 AM
Thank you!
I found that one of the disks was broken, the other 3 works fine. I replaced the broken one and are now letting the nas doing it's job. 🙂
Message 3 of 3
