joe_schmo
Apr 26, 2018Tutor
/var/backups/md
root@NAS:~# find /var -printf '%s %p\n' | sort -nr | head -20 1999268126720 /var/backups/md/tmp/wwn-0x5000cca251f3c069-part7 1999268126720 /var/backups/md/tmp/sdh7 1999268126720 /var/backups/md/tmp/ata-WDC_WD101KFBX-68R56N0_7PKNV77C-part7 8637575168 /var/cores/core-gdbus 246693888 /var/cores/core-readynasd 69976064 /var/backups/current_os.img 33986738 /var/lib/apt/lists/mirrors.kernel.org_debian_dists_jessie_main_binary-amd64_Packages 20916138 /var/cache/apt/pkgcache.bin 20851533 /var/cache/apt/srcpkgcache.bin 16777216 /var/cores/core-smbd 9928704 /var/cores/core-rsync 8388608 /var/log/journal/80c4898938f94d1e9ce2d6941a618096/system.journal 8388608 /var/log/journal/80c4898938f94d1e9ce2d6941a618096/system@faef121b8523437e80ca90776f25b31e-0000000000003866-000569d9b36d14f7.journal 8388608 /var/log/journal/80c4898938f94d1e9ce2d6941a618096/system@faef121b8523437e80ca90776f25b31e-0000000000001c3a-00056965fe13c209.journal 8388608 /var/log/journal/80c4898938f94d1e9ce2d6941a618096/system@faef121b8523437e80ca90776f25b31e-0000000000000001-000568c1439415e5.journal 8388608 /var/log/journal/80c4898938f94d1e9ce2d6941a618096/[email protected]~ 8388608 /var/log/journal/80c4898938f94d1e9ce2d6941a618096/[email protected]~ 8011776 /var/readynasd/db.sq3 7438336 /var/backups/readynasd/db.sq3 5045112 /var/subsonic/jetty/4428/webapp/WEB-INF/lib/org.eclipse.persistence.core-2.5.1.jar
Is this normal to see these files in /var/backups/md?
What are those huge files?
joe_schmo wrote:
Is this normal to see these files in /var/backups/md?No. My md folder has 64kb of data in it, and it has no tmp folder.
Perhaps check the file dates - if they are old (or if no backup jobs are running) it should be safe to delete everything in /tmp
You could copy them to the data volume if you want to be very conservative.
Thanks! I removed the tmp files... no idea why they were there, but really appreciate it.
- mdgm-ntgrNETGEAR Employee Retired
You should have raid_config_XXXX_XX_XX_XXXXXX.tar.xz files in /var/backups/md
Has support looked at your system for some reason? Sounds like they extracted one of those files but forgot to clean up afterwards.The compressed archive can be invaluable in a data recovery situation. So leave the tar.xz files but you can delete everything else in /var/backups/md
The files in /var/cores are core dumps. These can be useful for diagnosing why those services crashed. If they're recent you may wish to compress them e.g.
# cd /var/cores # lzma -9 core-readynasd
and keep them around in case they're needed for troubleshooting or if they're very old you could just remove them.
/var/lib/apt/lists contains the list of available packages to install.
/var/cache/apt contains the package archive of packages that have been downloaded.
/var/log/journal contains the main log for the system (this is rotated automatically).
/var/readynasd and /var/backups/readynasd contain important databases and backups respectively. Leave these alone.
Thanks for this...
I am trying to figure out why my rsync jobs keep hanging up on each file. It goes for a bit, then pauses, then starts up. I am only able to copy about 200MB a day and it's driving me crazy!
