- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Change password for added network
- Mark as New
- Bookmark
- Subscribe
- Permalink
How to reset the password for an added network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Change password for added network
Well, you gave us minimal info.
What device you have?
What you're actually trying to do. LIke reset the wireless? reset the login?
Not much at all.
You can always factory reset and then just follow the reinstall guide
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Netgear WiFi unit when accessed has the current network and a list of Available Networks (usually our neighbors) and a selection for +Add Network. I am connecting a security camera to a network that was added per install instructions. The added/camera network has a weak password (according to the camera company) and has suggested to us that we re-set the password.
My question: How do I change the password for the added (camera) network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still don't know what router you have?
Why do you think it has a weak password?
Why would the camera company tell you that?
what security method are you using? WPA2?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved!!!!
Per your reply:
Doesn't matter now!
I do not think it is weak, just wanted to update!
You will need to ask them what they think, as I am unable to read their minds!
Doesn't matter now!
