× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Im having issues with rebooting as well
Guru
Re: Im having issues with rebooting as well
Yes please.
Message 26 of 100
JesseDiaz
Guide
Update:  at 9pm PST, I took the 2 RBSs off of Ethernet and had the backhaul on the wireless configuration.  Since then, the router has rebooted 2 times with a current uptime of 5 hours.  So that didnt seem to work.  I just ended up ordering a new CAT6a STP and should receive it withing the next 2 hours.  Ill replace that and see what that does.......
Message 27 of 100
JesseDiaz
Guide
Update #2 - Got the new cat6a STP cable.  Installed.  Turned off modem and router for 2 minutes.  Powered on modem and waited until connection was established.  Then powered on router.  Have internet os now Ill wait to see if it reboots.
RBSs are still on wireless backhaul
Message 28 of 100
Guru
Message 29 of 100
JesseDiaz
Guide
Let’s assume this works and the reboots stop. Should I be using the same cables on my RBSs?
Message 30 of 100
Guru
Yes. STP cabling is recommended if your using the highspeed ports on the RBS.
For ports that don't use the highspeed connection, like 1Gb, then UTP cabling can be used.
Message 31 of 100
Guru
Could you please post the CPU, Memory usage and system uptime from the RBR and RBS IP address/debug.htm web page please?
Message 32 of 100
TOPS119
Apprentice
Since your on the topic of cabling I only get 250mbps internet from my provider am I required to use a cat 6a cable or can a cat 5 be used in this case ? Also is it anything above cat 5 like a cat 7 or cat 8 or is it specific to 6A ?
Message 33 of 100
Guru
For best operation, performance and avoiding any problems on the cable lines, CAT6A STP or anything STP is recommended.
Message 34 of 100
JesseDiaz
Guide
As soon as I get home , I can post the screenshot. Should I connect the RBSs back on the Ethernet back haul with the new Cat6a STP cables?
Message 35 of 100
Guru
Lets make sure the RBR hasn't rebooted with the RBS being wirelessly connected first. Can you give it 2-3 days of observation? IF no reboot is seen, then reconnect the RBS via ethernet using the STP cabling.
Message 36 of 100
JesseDiaz
Guide
Yep-Sounds like a solid plan.  Below is the screenshot you requested.  I dont want to jinx it but this is the most uptime Ive had since I purchased the router.  I also see my HOMEKIT devices responding now.  As a reminder, my devices were functioning only 50% of the time since I purchased the router.  AS of the current uptime of 21 hours, the devices have been working without fail....
Message 37 of 100
Guru
Ok looks good. Lets give this a couple of days of up time with the RBS wirelessly connected. IF good at 3 days, try reconnecting the RBS via ethernet. Use CAT STP cabling to connect them.
Message 38 of 100
JesseDiaz
Guide
Well it went good for almost 3 days but looking at the log, it robooted
and I was pulling this info, it rebooted again
Message 39 of 100
Guru
Going to recommend you make contact with NG support and either ask about any available beta FW that maybe you can try or ask about a cross RMA option:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".
Message 40 of 100
Guru
Message 41 of 100
JesseDiaz
Guide
Oh thank you.  Ive had no success with Netgear so Im going to try the beta firmware.  Im still going to call tomorrow though.
Message 42 of 100
JesseDiaz
Guide
FYI-  The firmware showed up in in my router
Message 43 of 100
Guru
I recommend a full power OFF of the ISP modem/ONT, RBR and RBS for 1 minute them back ON.
Message 44 of 100
JesseDiaz
Guide
Yep. Remembered you recommended that last time so I made sure to do it all this time. I’m crossing my fingers!!!
Thank you
Message 45 of 100
JesseDiaz
Guide
Urrghhh..lasted about a day then it rebooted
Message 46 of 100
Guru
Dang it.
Do you have IPv6, Armor, SPC or Traffic Meter enabled?
Something to check if you can please, would you keep an eye on the debug pages for the RBR and RBS? IP address/debug.htm. Please look at the CPU and memory usage values. Take note of what you see first, then say check back in a day again and check the values seen here. On the RBS web pages, check the Hop Count value seen here. Take note if the value goes blank.
I would do a full on factory reset and setup from scratch, when you have time. Follow this please:
https://community.netgear.com/t5/Orbi-WiFi-7-BE-Mesh-Systems/Procedure-for-Factory-Reset-of-RBE970-s...
Check the afore mentioned items. If you notice the CPU or memory usage go high or say higher than 10-15% for the CPU, there maybe some creep here that when getting high enough, causing the system to reboot.
@Straq
Message 47 of 100
JesseDiaz
Guide
I know I dont have IPv6 or Armor on.  Ill have to check on the other 2.  Ill also have to read through your request on the debug.  But if I confirm I dont have any of the  services you mentioned on, I think Ill do a factory reset for like the 25th time first before I start the debug request.  Seems like that would at least eliminate on variable
Message 48 of 100
Guru
Sounds good.
Something has to be causing this random reboot.
Message 49 of 100
Guru
Ok. Looking at the RBR data, Seems stable CPU and memory use wise.
03/10/2024, 08:27:09 9.03% 1124 MB/1743 MB 1 days 23:06:25
03/10/2024, 08:32:07 0 0 0 <<<I see where the reboot happened.
03/10/2024, 08:37:44 26.29% 1146 MB/1743 MB 0 days 00:04:35
All usage seems stable at this point:
03/11/2024, 17:36:13 8.40% 1121 MB/1743 MB 1 days 09:03:01
However the RBS, I'm seeing a slow creep upwards in CPU and Memory usage:
Poll Time CPU Load Memory Usage System Uptime Hop Count
03/09/2024, 11:24:01 9.88% 606 MB/1743 MB 2 days 16:16:31 1
And ended up here with last test taken by tool:
03/11/2024, 17:33:23 10.15% 673 MB/1743 MB 4 days 21:25:52 1
And maybe still climbing.
Is this RBS wireless or ethernet connected currently?
Message 50 of 100
Top Contributors
Discussion stats
  • 99 replies
  • 1750 views
  • 11 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
