sigswi
Mar 15, 2017Aspirant
1 router 2 satellites from different kits!
Hi Sometime ago (before purchasing) i opened this topic, asking whether it would be possible to purchase 2 orbi kits in order to use the 2 satellites with 1 router. the response was positive htt...
st_shaw
Mar 15, 2017Master
The devices come with a pre-loaded backhaul password that's the same on the router and satellite. Devices from two different kits will not sync.
You should be able to sync them using the Sync buttons on the router and satellite. Did you try that?
- sigswiMar 15, 2017Aspirant
yes, i pressed the synch button on the router, then ran downstairs and pressed the synch button on the satellite, if that's what you mean?
All of this after having reset to factory settings all units and before re-doing the remaining part of the set up .
didn't work. still magenta. what i am doing wrong?
- PhoenixVMar 15, 2017Apprentice
Hi,
I have the same situation....
Install one Orbi "kit" and get it up and running so that you have the Base and the Satellite pair operating properly. I then use the ORBI app on the iPhone and select "Add Sattelite" option - go through the workflow and the third sattelite from the second kit is recognized and the settings are automatically downloaded and updated by the router from the first kit. Took me all of 2 minutes! (I'd assume that the same can be done through the web interface as well but I have not done that).
to be honest before resetting to factory settings i looked everywhere on the web interface for an option to add a satellite. no luck
I'll see i i can install the app...
