tomsliwowski
May 02, 2017Apprentice
1700Mpbs backhaul much slower than 1000Mbps wire?
So I've had the Orbi system for 3 days now and it's worked well for wireless clients but I was wondering if I'm doing something wrong in regards to placement or configuration. My setup is the fol...
rhester72
May 02, 2017Virtuoso
1733 is max theoretical, not real world. Reality is about half that under ideal conditions, less depending on the distance and obstructions between the router and satellite.
Rodney
tomsliwowski
I know that 1733 was the theoretical max but I thought the days of WiFi overhead taking up half the available bandwidth died with 802.11g. I recall getting a LOT closer to max on 802.11n and definitelly close to the 866Mbps on 802.11ac.
- st_shawMay 02, 2017Master
tomsliwowski wrote:I know that 1733 was the theoretical max but I thought the days of WiFi overhead taking up half the available bandwidth died with 802.11g. I recall getting a LOT closer to max on 802.11n and definitelly close to the 866Mbps on 802.11ac.
WiFi still has lots of overhead, so 50-60% of the link speed is all you will get. I measure 575 Mbs throughput over my Orbi backhaul using iperf3.
- tomsliwowskiMay 03, 2017Apprentice
rhester72, fbraz50 and st_shaw thanks for the replies. So the starting point should be 50% or so of 1733 which is 866.5 or two of the 4 available 5GHz backhaul channels. Loosing another 20% for something like a wall would get me to about 693Mbps which is still double the rate that I'm actually getting.
In your opinions, what would be the best way to maximize the speed available? Should I try to relocate the router? (not super easy but maybe I can move it 2 feet to the left where it'll be closer to the Satellite) Should I disable MU-MIMO and Implicit Beamforming? This isn't a deal breaker for the system since it's been working well so far but I would like to maximize the performance especially to my main workstation.
- st_shawMay 03, 2017Master
tomsliwowski That 50-60% throughput is the maximum and requires the two wireless devices to be very close to each other. I've never seen anyone report more Orbi backhaul throughput than about 575 Mbps, so I'm not sure how fast you can get it to go. The 5GHz signals don't travel far and are attenuated by walls. Practical use of the Orbi requires the satellite to be separated from the router, probably one or more walls in between, so you shouldn't expect to get the 50-60% throughput with the satellite in a realistic location.
To optimize the connection, I would:
1. Download iperf3 on two machines (laptop or desktop is OK).
2. Connect both machines to one GigE switch and establish that you can get ~940 Mbps througput on a wired connection.
3. Wire one machine to the Orbi router and wire the other to the the Orbi satellite.
4. Test throughput with the Satellite in different locations and see what works best. You could start in the same room with no obstructions to see what the maximum speed is.
If you have any sources of 5 GHz interference they could lower your throughput. Using Sonos drops mine down to 500 Mbps.
