jmschnur923
Feb 20, 2018Luminary
2.0.1.4 firmware
I have the previous version. Should I change to this one? What features are gained or lost?
webminster
Going to 2.0.14 from the 2.1.2.18 release, you would lose wired Ethernet backhaul, and support for the Orbi outdoor satellite. If you need neither, you could downgrade,
Whether you should depends on your circumstance. If you're having issues, you might want to try. If not, I would not bother. 2.0.1.4 in my environment is not without problems, but appears to be the best version I've tried (and I've tried many versions so far).
