webminster
Dec 20, 2017Luminary
2.1.1.16, NTP, timezone/DST
With 2.1.1.16, you can specify an NTP server. But in the Web UI, I can find no place to set the time zone of the device, nor set DST tracking. Hence, the time on my Orbi is one hour off. Am I mi...
- Dec 20, 2017
I think the timezone is set in: Advanced -> Security -> Schedule.
Hydro130
Yeah, I really have no idea what that new NTP option brings to the fight, since it certainly doesn't set your local time properly. Anyway...
To set your local time, it's the same process it's always been -- once you're logged in to the Admin page, go to the Scheduling section.
I apologize here, I'm not home right now, so I don't recall the "path" to that particular page, but it's under the Advanced tab, then I think it's in the "Security" section - look for Scheduling options... In there soemwhere, there's a page where you can actually set both your local Time Zone and the option to use DST or not.
When I factory-rest my Orbi, it's always off by one hour too, so I have to do this everytime.
Hope that helps!
- Retired_MemberDec 20, 2017
wow...that's crazy. I thought that section about DST (buried inside somewhere) was IF you wanted to do some sort of web scheduling. The Orbi should pull the time from your modem or ISP I would guess.
