AFD's avatar
AFD
Luminary
Oct 12, 2019
2.3.5.30 - ORBI - Firmware AutoUpdate? Severe Problems with Satellite
Someone could help me in order to know why my devices appear with the referenced firmware? I didn't perform any action to start an update procedure and the firmware was installed without any single message .
The real issue is that now I have a terrible problem with the satellite , because no devices are connected to It,  and security cameras are now out of service , the alarm also , or have a poor and terrible service because of the distance to the main route (rbr50) .
Al lthe devices in the WiFi network are connected to the Main Orbi router than the Satellite that supoosed it should be , so you can imagine the performance of many of them .
Please let me know how to solve the problem and also if an automatic update was run without any notification to the user .
Urgent Support is requested
  • AFD's avatar
    AFD
    Oct 19, 2019
    Up & Running with 2.3.5.30 .
    Almost 2 days with no (bad) news . Everything seems to run fine with no noticed issues (until now).
    Satellite Devices are connected as expected .
    Cameras running ok
    IR/RF remote controls , devices and RF lights are operating as expected . (RF is posted because the remote controls are connecting to Orbi wia WiFi and send RF signals to different devices)
    Keep you posted in case of problems .
    Thanks to everybody for helping and supporting
  • I also have a very similar issue - my main orbi keeps updating to V2.3.5.12_1.0.8, and on this version my satellites don't show as connected, although on the home screen they do show.  If I go through all the hoops to downgrade it to 2.2 it works perfectly.  Yet - I can't tell it to NOT upgrade.
    Plus - i can't do chat or email support with netgear after 90 days?  Yet, they upgrade my system w/o letting me choose?  I am not really understanding that.
    What options do I have?
    Matt
    • AFD's avatar
      AFD
      Luminary
      Thanks for answering . Im still working in the problem which is very severe , I have a lot of devices in 2.4 GHZ range connected to the satellite that today do not respond because all of them are connected to the main router .
      Im thinking in perform a factory reset and reinstall the previous version which was running perfectly well . (2.3.1.44 in my case) .
      Im going to post here the different tests done before resetting . I dont want to rollback to a previous version (despite I didnt decide to install it) , but lets see .
      • AFD's avatar
        AFD
        Luminary
        I'm going to disconnect (turn off) and connect (turn on) all the devices that supposed to be connected to the satellite to see what happens . Turn off/on the main router and the satellite didn't solve the problem until now . This is the third day with the issue , so I think is enough time to allow the roaming of the devices by themselves . Besides is not only the cameras (there are some alarms , sensors and smartplugs that suppose to be connected to the satellite.
        During today I'm going to perform this action and let you know .
  • Hey I was on firmware .44 also and it was to never supposed to update my firmware past that. the past couple days Ive been getting terrible restarts/rebooting. Some how my updated the firmware by itself also to 2.3.5.30. Not happy about this. Mine was rock solid on the .44
    • mathewbeall99's avatar
      mathewbeall99
      Well - I factory reset everything.... always fun to spend 45m doing that.  We will see if it's more stable.
      I don't even see an option that says "don't update firmware" in my version, unless its hidden somewhere.
      • plemans's avatar
        It didn't say don't update my firmware. It just doesn't update unless you click on the notification at the top.
