ekhalil
Jul 29, 2019Master
2.3.5.30: Wrong behavior when logging in from multiple computers
In previous firmware releases, when you try to log in to the web GUI using orbilogin.com or 192.168.1.1 and you're already logged in using another computer, you would get a question if you want to continue to login and thereby log out the already logged-in user.
In 2.3.5.30 you will just get the message when trying to log in from the other computer:
5000 - Internal Server Error
Not my experience. Attempted just now and got the same response as usual. Did I want to log out the the already logged in user.
RBR50 on v2.3.5.30.
Maybe there was "something going on at the time" that had the Orbi confused?
Reboot is pretty easy to time for me. "Reset to factory" is the one I dread.
