Kyle198's avatar
Kyle198
Follower
Jan 02, 2021
2.4 to 5ghz
I need help, just bought an Orbi mesh system, i can't connet most of my lights and switches to 5ghz, is there any way to change it to 2.4? I'm a novice at this.
1 Reply
  • FURRYe38's avatar
    try turning down the 5Ghz power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    You can temporarily disable the 5Ghz SSID broadcast as well.
