Z_zz
Apr 25, 2020Aspirant
2 routers inline issues?
I have RBK50-100NAS, 2 router systems. 1-at house modem and older netgear router ac2200. 2-installed a orbi router in barn with a satellite(big 2 story work barn) connected with ground cat6 (200feet...
Z_zz
Apr 27, 2020Aspirant
And if I do AP fo I select dynamic or fix IP?
Apr 27, 2020Guru - Experienced User
Either. I like fixed so I always know the IP address of the RBR in AP mode. I use 192.168.#.50 for mine when it's in AP mode.
IP needs to be outside of the host routers IP addess pool, so the main host router should be set for 192.168.#.100 to .200. Then you can use static IPs on any device on either side of this pool.
