pmainstone's avatar
pmainstone
Follower
Jun 15, 2019
400 Bad Request message after updating RBR50 firmware to V2.3.1.60
I have just updated my ORBI RBR50 Router to firmware V2.3.1.6. When I log onto the router I am presentred with an "Enable CIRCLE with Disney" pop-up screen. I can see the ORBI menu behind. The pop-up has always been there and I have just closed it in the past. After the update the pop-up appears and whatever I do to remove it, I get a "400 Bad Request" message and I can not access the Router menus.
Help!
  • CrimpOn's avatar
    CrimpOn
    Is this on the Orbi web interface or on the Orbi "app"?
  • FURRYe38's avatar
     Please do a factory reset on the Orbi system and setup from scratch.
    Help!
    • Dwtrux's avatar
      Dwtrux
      Initiate
      Is every solution to Orbi problems to do a factory reset?
      seems very user unfriendly.  Router and wifi working but just can't access over Orbi iphone app locally but can remotely so I will leave as.
      • Retired_Member's avatar
        Retired_Member
        It’s more of the copy/paste mentality
