Retired_Member's avatar
Retired_Member
Feb 06, 2020
"404 not found" when trying to access adminpages
Hi
My router suddenly started to show a 404 Not Found when I try to login to adminpages. I asks for username and password and then show 404 Not found. Also tried to access the debug page https://192.168.1.1/debug.htm and I then get a "500 Internal Server Error". Anyone have a clue, as I dont want to factoryreset?
AJ
  • FURRYe38's avatar
    Does http://192.168.1.1/debug.htm work? Don't use HTTPS.
    What browser are you using? Try IE11, FireFox or Opera.
    Be sure to clear ALL browser caches, exit the browser then re-launch and navigate to the RBRs web page.
    • Retired_Member's avatar
      Retired_Member
      Firmware: 2.5.1.8
      Same problem with http://
      Get 500 Internal Server Error
      The orbi app also have problem and cannot login anymore. Reboot tried also, but no go
      • FURRYe38's avatar
        The RBR is in a bad state, press the reset button in back for 15 seconds then release. Use a wired PC and setup the RBR from scratch.
