Carla1
Jul 08, 2018Follower
4PM26A51099A0 WIFI IS DROPPING ON MY PHONE
Need help my phone keeps dropping the wifi. Nothing else is dropping just my phone. Any suggestion on how to fix this or why it's happening?
Jul 13, 2018Guru - Experienced User
Try downgrading then.
Orbi is a router thus is has the ability to router traffic or be used in AP mode. So depending upon your network needs, routing maybe necessary.
Try this:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
No problems after settin up my friends system:
