stevekatz
Oct 14, 2018Follower
90 Day tech support? How do I get access?!
Bought an RBK50 Orbi mesh network yesterday and am having nothign but trouble setting it up. The product is suppsoed to come with 90 days of free tech support via email, chat, phone - but NONE OF IT ...
Pureedfruit
Nov 20, 2018Initiate
I too am trying to get my ORBI RBK50 working and found that NETGEAR tech support have simply spun me aroundin circles. I am trying to get my RBK50 to connect to my PLUSNET (a UK ISP) HUB ONE router WAN port by cable. I understand this router to be a SAGEMCOM fibre router derivative in which the critical (at least as far as connecting the RBK50 is concerned ) "Bridging" feature has been made not operable in the PLUSNET version, which is why the RBK50 will not connect to the Internet, which makes it pretty useless.
I am no techie so what I would like to know is:
Is my understanding correct so far ?
If so what other options do I have ? e.g.
Are their suitable fibre routers that do support bridging, and if so which ?
Is there an alternative way of connecting the RBK50 to the HUB ONE ?
Any help will be much appreciated.
And before you ask YES I have contacted PLUSNET who simply washed their hands of the problem and refered me to NETGEAR.
Nov 20, 2018Guru - Experienced User
What FW is currently loaded?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
