bearyoung
Nov 13, 2019Aspirant
a new satellite from other sales region
just moved from US to Europe and brought the RBK23 with us, can I buy a new satellite here from a local seller? I believe the they have different versions, RBK23-100PES and RBK23-100NAS? will this co...
Nov 13, 2019Guru - Experienced User
Your issues will be:
1. Region setting. Each region has their own setting for wireless regulations and usage. the US ones have the region locked. You can change it but it'll take a little effort on your part. There's multiple posts in the forums. Read a few of them to see if thats within your capabilities and if so, you should be good. Here's one for example.
https://community.netgear.com/t5/Orbi/ORBI-RBK53-Region-Change/td-p/1743684
2. Power supply. The EU uses a different power standard. You can either get a different power supply or an adapter as I think most power supplies will take the EU power but just needing the plug adapter.
Once the regions changed, you should be able to add the satellite without issues. *should* being key word.
- michaelkenwardNov 16, 2019Guru - Experienced User
You may not even to change the region, although it is probably a good idea.
Someone sent me an Orbi satellite from the USA. It worked OK with "native" UK stuff.
