- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBK53 Region Change
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you'd like to save some bucks and buy Orbi from Costco and bring it home outside the US, but you want to make a region change from North America to your region, try this:
1. Login to Orbi/debug.htm page and enable telnet (tick telnet box)
2. telnet into Orbi and type these:
- root@RBR50:~# rm /tmp/firmware_region
- root@RBR50:~# echo WW > /tmp/firmware_region
3. Check the result, it should return WW
- root@RBR50:~# cat /tmp/firmware_region
Go back to Advance Wireless Settings page and refresh it. You should be able to use Region Selection drop down menu to select your region. Alternately, you can also use artmtd command, see @ekhalil's trick.
Good luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBK53 Region Change
Nice idea. Does not work with the RBW30.
Nor does artmtd.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't have access to RBW30, have you tried loading French firmware and see if that works for RBW30?
- Mark as New
- Bookmark
- Subscribe
- Permalink
For months I couldn't find a solution to my Raspberry Pi (Model 4) disconnecting reguarly from the AC3000. (To be more accurate - it was staying connected to the Orbi wifi, but somehow, had no access to the Internet). The Orbi was purchased in Canada, but the Raspberry Pi came from Europe. I repeatedly tried adjusting the Localisation settings on the Pi - but to no avail.
Then I came across this post. Although it specifies the RBK53, I decided to try it on my RBK50.
It's now 48 hours since I changed my Orbi to Europe and I'm delighted to see that I'm still attached to the Internet. Many thanks.
If someone has an explanation about what's going on here, I'd love to hear it. If my Pi is set to US, and my Orbi to North America, why would it repeadedly disconnect? Why would placing them both on Europe make a difference?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My guess, and it is no more than that, is that the communications standards are different.
Stuff sold in Europe is not locked to a region. The browser graphical user interface (GUI) lets us change it, with a dropdown that covers most of the world.
In the USA they lock them down. (I got sent one from the USA.) This is probably because the FCC, or whoever sets the rules, does not allow the use various wifi bands and perhaps other things. So Netgear, and others, may just be following the law.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mike_D_il wrote:For months I couldn't find a solution to my Raspberry Pi (Model 4) disconnecting reguarly from the AC3000. (To be more accurate - it was staying connected to the Orbi wifi, but somehow, had no access to the Internet). The Orbi was purchased in Canada, but the Raspberry Pi came from Europe. I repeatedly tried adjusting the Localisation settings on the Pi - but to no avail.
Glad to hear that this trick works out for you. Thanks for your feedback!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please excuse a couple of basic questions regarding how to telnet into Orbi. I've enabled telnet access and tried to access the router via ssh on my Mac. Mac no longer has telnet included with its OS.
- Do I need to use telnet, or should ssh work?
- If ssh works, would the commands be the same?
- In either case, what do I need to enter on the command line in Mac terminal to proceed? WhenI enter ssh admin@[ip address] access is denied.
Thank you.
Bill
- Mark as New
- Bookmark
- Subscribe
- Permalink
192.168.1.1/debug.htm then select the check box next to Enable Telnet to enable it. You have to enable it first to access telnet.
@BillTh wrote:Please excuse a couple of basic questions regarding how to telnet into Orbi. I've enabled telnet access and tried to access the router via ssh on my Mac. Mac no longer has telnet included with its OS.
Thank you.
Bill
- Mark as New
- Bookmark
- Subscribe
- Permalink
As far as I can tell, Orbi does not support ssh.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you.
Bill
Apple removed telnet cmd from macOS. If you want to get telnet cmd back, check out this how to enable telnet cmd on macOS.
Good Luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the help! I installed telnet on my Mac and it worked fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Bill,
From my recollection it was pretty simple and I didn't need to add anything to my MAC. You should use Telnet, not SSH. Take a look at this:
https://www.siteground.com/kb/mac_terminal_telnet/
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Mike. Unfortunately, Apple has removed Telnet from its OS in recent releases. Here's a link that talks to that and provides options to install Telnet. I went with the first option.
Bill
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI, this no longer seems to work. I tried with my router firmware is V2.3.5.30.
I telnet succesfully and change the file but when I login it doesn't give the option to change region under advanced wireless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you explain exactly what you did?
What do you mean by "change the file"?
My memory is that this is what I did:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I enabled telnet and telnetted in,
I used both:
and check the result, it should return WW
also
artmtd -r region
The region number is: 0x0002
REGION: WW
I logged back into the router and went to the advanced wireless and refreshed. This is what I see:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Region is on the Advanced Tab->Advanced Setup->Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
@simzhewei wrote:I enabled telnet and telnetted in,
I used both:
also
artmtd -r region
REGION: WW
Just tried this on the latest FW version (v2.5.0.40) and it's still working for me. Check out the attached picture.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the screenshot. I realised my firmware wasn't up to date. Though I had used the app to update it, it was still only on version 2.3.5.30. Having said that even after manually updating to the latest firmware (2.5.0.40) I still don't see region setting changes. In fact my advanced wireless settings menu looks much more basic than the screenshot you have provided.
Please see mine attached. If any ideas how to fix this, please let me know! BTW just checking but I am using RBK53, I'm assuming that this is exactly the same model for everyone?
Cheers,
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, but the instructions are generic, for all models. Just change the instructions.
@simzhewei wrote:BTW just checking but I am using RBK53, I'm assuming that this is exactly the same model for everyone?
Cheers,
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are still on the wrong screen. On the Advanced Tab, go down to the bottom, to Advanced Setup, then Wireless Settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am an idiot. Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
We idiots have to stick together. Technology has made our lives plenty complicated. Good Luck with your Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I successully did it on my 2.3.5.30 this morning.
- Mark as New
- Bookmark
- Subscribe
- Permalink
On my setup, it seems to revert back to "US only" now and again. (I DO click Apply). I can't find anywhere that the Orbi automatically updates. What am I missing?
Thanks,
Mike
