77PALE77's avatar
77PALE77
Apprentice
Apr 05, 2019
About printer through ORBI
Hi guys,
I recently extended my wi-fi with ORBI. Let’s call the original wi-fi WIFI1. ORBI is connected to the WIFI1 modem via ethernet with its IP (192.168.1.100) and generates a new wi-fi signal: let’s call it WIFI2. ORBI has a different class of IP’s (10.0.0.x). I have a printer connected via WPS to WIFI1 with its IP address 192.168.1.108. It only works if a device is connected to WIFI1.
Is there any way to use it connecting a device to WIFI2 and routing the connection to the printer in some way?
Thanks a lot
Pale77
  • Thanks a lot, it now works fine.
    I only had followed the setup instructions and it had set as two routers one after the other.
    Now it is in AP mode and the only one anomaly is that I connected to the ORBI router an audio device via ethernet and it isn't shown within the connected devices. Strangely it is shown with 192.168.1.106 IP in the modem/router, but anyway it works fine.
    But in AP mode it seems impossible to remotely access the ORBI (te selectioni s shown in grey and cannot be activated): is that right?
    Thanks again
    Pale77
  • CrimpOn's avatar
    CrimpOn
    What device(s) are attempting to use the printer from the Orbi Wi-Fi?  (i.e. desktops, laptops, PC, Apple, tablets? etc.)
    I think the problem will "go away" if the Orbi is set into Access Point (AP) mode.  On the Advanced tab, select Advanced Setup, select Router/AP Mode.  In general, it is not a good practice to stack one router behind another.  When every device is getting an IP address directly from the first WiFi router, devices should "find" the printer with no problem.
    • 77PALE77's avatar
      77PALE77
      Apprentice
      Thanks again
      Pale77
      • FURRYe38's avatar
        When in AP mode, some features like remote access are no longer enabled.
