Misquet
Sep 26, 2021Tutor
AC Power adapter Orbi RBK353
Hi,
I need a AC Power Charger for the Orbi RBK353 (Europe/Holland Version).
I assume you can also use universal chargers however I am not sure which type?
Can you please help?
Thanks a lot
According to the manual:
North America: 120V, 60 Hz, input
UK, Australia: 240V, 50 Hz, input
Europe: 230V, 50 Hz, input
All regions (output): 12V, 3.5A DC outputSo you'd want a 3rd party supply with a 12v 3.5amp output.
yes you can use a 3rd party power supply. You just have to make sure it has the same voltage and polarity output as the original. It can have higher amperage but not lower.
- MisquetTutorThanks for you're help.
Do you perhaps have suggestions?
I have bought a set of 3 without the power supply (not shipped / received yet) and want to order however not sure which one to order?- plemansGuru - Experienced User
