BH121
Mar 25, 2018Follower
AC2200 vs AC3000 with ethernet backhaul
I am setting up wifi in a new house which has ethernet cabling installed. Therefore I am planning on ethernet backhauling. What I cannot figure out is if there is any advantage of purchasing the RB...
Mar 26, 2018Guru - Experienced User
The specs are listed here: https://www.netgear.com/orbi/
Mostly the wifi connection rate is 1.7Gb between router and satellite while the other is 866mb. This is only the connection rate between router and satellite.
