drafferty
Jul 27, 2025Aspirant
AC3000 RBR50 compatible with CAT6 cable
I understand this is older MESH system. This router has most recent firmware 2.7.5.6 For one will this network support 1GB? Current ISP and plan is 500mbps. All works as planned. What speeds shoul...
CrimpOn
Jul 27, 2025Guru - Experienced User
Yes, the RBR50 router has a gigabit Ethernet port and will connect to a gigabit ISP service. Because there is overhead (even with Ethernet), it is impossible to realize the full gigabit of bandwidth.
Most users report more then 920Mbps.
The RBR50 is WiFi5 (802.11ac). The highest speed most mobile devices can realize is about 800Mbps.
Yes, the RBR50 is totally compatible with Cat5e and Cat6 Ethernet cable.
drafferty wrote:Is it easy to replace existing system ac3000 say to 770 system?
For a lot of users, it is simply "plug in and go". Configure the new system with exactly the same WiFi credentials as the RBR50 (SSID/password).
There is a Community Forum dedicated to the WiFi7 product line (which includes the 770). Realizing that customers who experience zero issues are not likely to bother with joining a user forum, there is no way to determine what percentage of customers experience 'problems'. If you search the forum for the 770 product, there definitely have been "issues" for some customers.
