drafferty
Jul 27, 2025Aspirant
AC3000 RBR50 compatible with CAT6 cable
I understand this is older MESH system. This router has most recent firmware 2.7.5.6 For one will this network support 1GB? Current ISP and plan is 500mbps. All works as planned. What speeds shoul...
drafferty
Thanks, I now think the apple TV device , an older gen(1st gen 4k) becomes spotty and buffers when at 1GB wifi.
- CrimpOnJul 27, 2025Guru - Experienced User
If the current ISP connection is 500Mbps (from the original statement above), how can the Apple TV be connected to 1G WiFi?
This Apple TV has the same WiFi capabilities as the RBR50. (802.11ac). Actual performance will depend on distance from the WiFi access point and anything "in the way". For example, people often push electronics behind the TV set, which can drastically affect WiFi performance.
